Old 12-06-2010, 08:50 AM   #1
Hardwood to Vinyl step
I have just finished installing a hardwood floor in a sunken family room (1 step down). The adjoining floor is vinyl with a 6 foot opening. My wife has suggested that we install a 6 or 8 inch wide hardwood plank with bullnose, flush with the vinyl making it look like a stair step. I'm thinking that maybe a 2 or 3 inch would be more appropriate due to the two different flooring materials. We are planning on changing the vinyl to tile at some point in the future.
Any comments on what would look best?
vinyl____
I Hardwood
thanks, alstan
alstan is offline   Reply With Quote
Old 12-06-2010, 09:50 AM   #2
The bullnose should be hanging over 1/2" to 1". 2-3" wide just won't be as stable. Use, one that's wider. It will look good with the tile too.(don't do the step with tile when you do tile. It will tend to chip and break) It will stand out a little, but its a step you don't want it to perfectly blend for safety's sake.
Edit to my post: the tile will raise the level of floor. Go with one of those metal floor trim pieces to finish off the vinyl.
Swith to wood to make up the height when you add backer board and tile.
michaelcherr is offline   Reply With Quote
The Following User Says Thank You to michaelcherr For This Useful Post:
alstan (12-06-2010)
hardwood floor to carpeted step transition DIYguy2000 Carpentry 7 11-06-2009 01:09 PM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 08:19 PM
Vinyl Tile Over Hardwood LGrey Flooring 1 02-16-2009 11:34 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
