Old 12-14-2011, 02:53 PM   #1
Hardwood thicker than railing base - Help needed
We are installing 3/4" hardwood throughout the main floor of our house, but the railing base it will butt up against is 1/2". Should we remove railing and railing base and put a thicker base on it? Or are there other solutions such as transitions / mouldings? We can't (necessarily) reinstall the railing base on top of the hardwood because then you would see the unfinished hardwood end from the stairs.
Any innovative ideas here?
jenhib is offline   Reply With Quote
Old 12-14-2011, 02:57 PM   #2
Disabled wood vet
titanoman's Avatar
You could do as you stated then trim the exposed end grains with a chair rail or something. Or cap the hardwood with a molding and butt that up to the sole plate.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-14-2011, 03:34 PM   #3
STAFF
BigJim's Avatar
You can do a couple of things, you can shim a 1/4 inch and be level with the floor and install a small trim to cover the shims. Or you can use a router and camphor or round over the flooring where it butts. Or you can install a small trim against the raw ends of the floor such as a 1/4 inch quarter round.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
quick help needed regarding paver patio base vetting Landscaping & Lawn Care 2 04-21-2010 05:01 PM
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 10 01-25-2010 11:01 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 04:29 PM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 04:35 PM
