-   -   Hardwood thicker than railing base - Help needed (http://www.diychatroom.com/f5/hardwood-thicker-than-railing-base-help-needed-126619/)
jenhib 12-14-2011 01:53 PM
We are installing 3/4" hardwood throughout the main floor of our house, but the railing base it will butt up against is 1/2". Should we remove railing and railing base and put a thicker base on it? Or are there other solutions such as transitions / mouldings? We can't (necessarily) reinstall the railing base on top of the hardwood because then you would see the unfinished hardwood end from the stairs.
Any innovative ideas here?
titanoman 12-14-2011 01:57 PM
You could do as you stated then trim the exposed end grains with a chair rail or something. Or cap the hardwood with a molding and butt that up to the sole plate.
Sent from a Samsung Galaxy S2
BigJim 12-14-2011 02:34 PM
You can do a couple of things, you can shim a 1/4 inch and be level with the floor and install a small trim to cover the shims. Or you can use a router and camphor or round over the flooring where it butts. Or you can install a small trim against the raw ends of the floor such as a 1/4 inch quarter round.
