Hardwood Surronded By Granite Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 05-09-2005, 01:23 PM   #1
Hardwood surronded by granite tiles
Hello:
Have a question about laying wood floor within a grainte tile perimeter. Granite tiles are being set over concrete subfloor. Hardwood is a floating floor, over concrete, that will be glued together. I know there needs to be some space to allow expansion and contraction of the wood floor but how much space? Don't want there to be large gaps between the wood and granite. Can I use a silicone caulk to fill the space? What would happen if I did not allow space for expansion and contraction? Climate condidtions-work in being done in S. California very close to the ocean in a high rise condo. Any suggestions?
coleen66 is offline   Reply With Quote
Old 05-09-2005, 07:11 PM   #2
Contractor
If the two floors are close in height you can use a standard 'T' type transition. If they are not close, you may want to look into having transitions made. I often make my own.
If a floating floor can not expand and contract, it will generally bubble ( a large hump in the floor).
Teetorbilt is offline   Reply With Quote
Old 05-10-2005, 12:42 AM   #3
Floorwizard's Avatar
Sometimes a baby threshold can be used as well depending on the thickness of the wood and Granite. Also called an end cap.
Floorwizard is offline   Reply With Quote
Old 05-12-2005, 10:34 PM   #4
Thanks for the helpful responses.
Old 05-13-2005, 05:10 PM   #5
747
registered
747's Avatar
Rewards Points: 534
Just Remember The Type Of Hardwood Floors You Have Need To Expand And Contract As A Unit. Make Sure You Don't Mess That Up.
747 is offline   Reply With Quote
Old 03-22-2008, 04:56 PM   #6
Hardwood surrounded by granite tiles - In a bind
Does anyone think this can be helpful to prevent condensation from ruining a hardwood flooring? Moreover, can this look good?
ens82271@aol.com is offline   Reply With Quote
Old 03-22-2008, 05:11 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 388
I think you should make up your mind....one or the other! These kind of projects rarely work right.
BTW, I think the above replies didn't understand what Coleen wanted to do. Otherwise they wouldn't have suggested T-molding or baby-thresholds.
Jaz
Old 03-22-2008, 05:39 PM   #8
Jaz
Okay, but I am being told that this is the "solution" to a condensation problem with this condo unit which has floor to ceiling windows as exterior walls. Does this ever work? What do you mean these projects rarely work right?
Old 03-22-2008, 06:06 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 388
Maybe you should start from the beginning, I have no idea what you're talking about with windows and condensation.
Please explain your situation in detail.
Jaz
Old 03-22-2008, 06:21 PM   #10
Jaz
Okay, sorry. I have noticed condensation (I believe) that has ended up on the floor (concrete). No surface has been placed on the floor. The developer wants to place tile at the perimeter of hardwood flooring I would like to place. Any ideas?
Old 03-22-2008, 06:22 PM   #11
I am having a condo built with floor to ceiling glass windows as exterior walls.
Old 03-22-2008, 08:08 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I can tell you a "floating floor" IS NOT the answer to condensation issues.
What exactly are the issues?
Where is the condensation coming from?
What is the heat source?
If this is a new condo how do you know you have condensation issues?
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 03:07 PM
Decorative Etched Granite Listello csteinke Remodeling 1 06-08-2007 11:54 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 07:43 PM
Vinyl Tiles over pre-existing layers Thwiipp Flooring 1 09-05-2006 01:10 PM
