Hardwood Surface Application - Flooring - DIY Chatroom Home Improvement Forum
Old 09-12-2011, 08:33 AM   #1
Hardwood surface application
I just laid a 2 ľ red oak plank floor in living, dining, kitchen, hall and master bedroom. Itís unfinished and Iím using Waterlox to cover it. I have put down two coats of original formula sealer/finish. This is the first time Iíve used this product. The company recommends two coats of the sealer/finish and then a top coat of finish (Iím using high gloss) for hardwoods such as oak.
After the second coat of sealer/finish the flood is starting to look like its got a coating. I can see some shine, but it does not look really coated yet. Is this normal? Iíve only used polyurethane before so it always looks coated after the first application. I can still feel some wood grain/texture on the floor after the second coat so I donít know if I should add another coat of sealer/finish or go ahead with the top finish coat. Also, if I do add the top high gloss coat and it looks like I need another, can I just add another top coat? From what I can tell you can just add more and more of Waterlox and it just keeps building up the surface. Anyone have experience using Waterlox that can help advise me?
Geneticswhiz is offline   Reply With Quote
Hardwood over OSB & transition issue janralix Flooring 4 05-02-2011 11:29 PM
removing/reducing hardwood transitions Drizzt Flooring 2 04-09-2011 06:35 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 10:20 AM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 07:06 AM
