Hardwood Stairs And Transitions - Flooring - DIY Chatroom Home Improvement Forum
Old 04-14-2009, 09:54 AM   #1
Question
Hardwood Flooring and Stair Transitions
I'm about to install hardwood flooring and have two staircases to deal with. I understand the basic technique for the stairs, but have a question on how best to do the bullnose on the top step for each one. My initial idea is to install the bullnose then set my chalk line using that piece as my reference line. From there run the courses in the hallway and continue into the bedrooms. I would perfer to run the initial courses based on the longest continuous wall, but the stairs have me concerned. Any thoughts on how to tackle this would be welcomed.
Grumpa is offline   Reply With Quote
Old 04-14-2009, 10:11 AM   #2
Still Learning
If you read into this discussion by not starting off the nosing you're likely to have problems with alignment. For example, it's almost impossible to distinguish what the installed measurement will be with 15 courses/rows of 3" wide plank (example)
The math comes out to 45 inches (15 rows x 3 inches) but depending on the product quality and how it's installed there's likely to be what I call a gain. The measurement may become 45 3/8" once installed. What you want to avoid is being off at the stairs if the flooring is running paralell. Imagine what it would look like with a 3/8" sliver or fill piece. Then if the squareness if off you may have some areas tapered from 1/8" to 3/8" as an example. Trust me it's very diffucult to get that kind of piece cut to fit perfect without looking like a botched job
HardwoodGuy is offline   Reply With Quote
Tags
flooring , hardwood , stairs
Installing Hardwood questions myphaykename Flooring 10 01-23-2009 08:48 PM
Painting transitions sherlock Painting 2 04-30-2005 02:03 AM
