Hardwood Stairs - Hiding Gaps - Flooring - DIY Chatroom Home Improvement Forum
Old 05-20-2012, 04:17 PM   #1
Rewards Points: 24
Question
hardwood stairs - hiding gaps
Any suggestion how to hide the gaps between treads and walls?
https://picasaweb.google.com/1088643...eat=directlink
Thank you!
ozdiy is offline   Reply With Quote
Old 05-20-2012, 05:53 PM   #2
DIY staff
Rewards Points: 7,174
It's to late now---you should have added a skirt board to the wall while the steps and risers were out--
Not sure how to make that look pretty--someone hare will offer up a fix--Mike---
BigJim (05-20-2012)
Old 05-20-2012, 06:24 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 130
1/4 round.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 05-20-2012, 07:18 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
It isn't too late for installing a skirt board, it is just going to be a little harder, here is a link showing how to install a skirt board after the stairs are finished.
Stairway skirt board template - easy
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
kwikfishron (05-20-2012)
Old 05-20-2012, 07:30 PM   #5
Rewards Points: 130
1/4 round was very common on the edge of steps 50 years ago. Probably the easiest route.
Old 05-20-2012, 08:48 PM   #6
Stairguy
Millertyme's Avatar
Rewards Points: 508
if there is no skirt, molding wont help.
Millertyme is offline   Reply With Quote
Old 05-20-2012, 09:01 PM   #7
Rewards Points: 13,752
http://images.search.yahoo.com/image...mb=Xwi4JCiNfjZ
To late now to be asking. if you want it to look right do it over, this time install the skirt before the treads.
I use one of these when cutting the treads to length. Each one can be a little differant in length and slightly differant angle.
Old 05-20-2012, 09:16 PM   #8
Rewards Points: 130
You are wrong. It was common 50 years ago and would be the easiest route. I don't like the look but have seen it done many times.
Old 05-21-2012, 12:22 AM   #9
Rewards Points: 24
Oh boy….for what is worth, only two stairs are screwed and well glued. The rest of the treads lay down freely not attached to the stair frame. I am frustrated….I can cut the nose and install a new carpet. Oh boy…
This is what I have found….not sure if that can be successfully done by me…there are way too many precise cuts.
http://www.thisiscarpentry.com/2011/...-skirt-boards/
Or use moldings as suggested…many cuts too but on individual pieces which should be easier.
This stair is part of a split level house. The other stairs leading to the main floor are untouched. I planned to remove the carpet there too but now I am not sure. Oh boy...
Old 05-21-2012, 09:36 AM   #10
Rewards Points: 24
Here is what I am thinking right now…
- install skirt boards for the 4 stairs that have not been installed.
- install skirt boards for the 2 completed stairs using these technique: http://www.thisiscarpentry.com/2011/...-skirt-boards/
If both kind of skirts installed, sanded and painted white, it should look like a one pice and professionally.
What do you think?
Old 05-21-2012, 08:15 PM   #11
I ran into the same issue at my own house. Just tape off the stairs, skim with drywall mud, sand, and repaint the walls.
RhodesHardwood is offline   Reply With Quote
Old 05-22-2012, 07:25 AM   #12
Rewards Points: 24
Thank you for your tip!
Does it look professional? I would love to see itů..
Hardwood or Carpet on Stairs? RugbyLove Flooring 3 11-16-2011 03:19 PM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 06:06 PM
Ideas for refinishing hardwood stairs?? RinSF Flooring 10 06-01-2010 03:25 AM
Hardwood & Stairs budcam Flooring 4 09-15-2009 11:12 PM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 01:31 PM
