Hardwood Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 12:49 PM   #1
Hardwood stairs
I have unfinished oak stair treads however I'm not quite sure how to install them. I have seen some people say to screw them an others have said to glue. Any suggestions?
mmostek4 is offline   Reply With Quote
Old 02-24-2013, 01:30 PM   #2
funfool's Avatar
Rewards Points: 534
I use liquid nails and a 15 gage finish nailer.
funfool is offline   Reply With Quote
Old 02-24-2013, 02:52 PM   #3
Rewards Points: 264
I agree with fun. We use 15 gauge nails and some pl400 construction adhesive.
Awoodfloorguy is offline   Reply With Quote
Old 02-24-2013, 03:03 PM   #4
Thanks for the advice. Very helpful.
Old 02-25-2013, 08:04 PM   #5
Rewards Points: 264
No problem. Happy to help.
Old 05-12-2013, 11:18 PM   #6
Rewards Points: 152
Is is better to buy unfinished treads & finish them yourself? Or if you're not too picky about stain, are the finished ones as good or better than you can finish them yourself? Are they worth the $20 premium? Do the prefinished wear better?
lazzlazz is offline   Reply With Quote
Old 05-13-2013, 06:08 AM   #7
DIY staff
Rewards Points: 7,174
The trouble with prefinished? There are a lot of cuts to be made---and nail holes---and a matching riser----so there is a good chance that the prefinished will have some cut and patch marks to hide.
Finishing a staircase is a lot of work---if you can avoid the problem of hiding all cuts then,consider it---I have always used raw wood and finished after installing----
BigJim (05-13-2013)
Hardwood or Carpet on Stairs? RugbyLove Flooring 3 11-16-2011 03:19 PM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 06:06 PM
Hardwood Stairs warnerww Flooring 9 04-24-2010 07:56 AM
Hardwood & Stairs budcam Flooring 4 09-15-2009 11:12 PM
Need to carpet hardwood stairs clasek Flooring 7 04-21-2009 11:00 AM
