Hardwood Section - Flooring - DIY Chatroom Home Improvement Forum
Old 05-29-2011, 06:25 PM   #1
Hardwood Section
I have a carpeting living area and I wanted to section off a corner and install hardwoods just large enough to place a bar with a few stools (it would be where two walls came together). Is it possible to just rip out a section of carpet, hard hardwoods, and make the seams look decent where they come together? If so, what are the steps or if anyone knows a step by step guide for this. Your help is greatly appreciated!
Knight30 is offline   Reply With Quote
Old 05-29-2011, 06:56 PM   #2
DIY staff
Rewards Points: 7,174
It is possible---is it possible to simply pull back the carpet in the area to get the wood?
I always just call in a carpet installer to reinstall the carpet---Those guys are magicians (my carpet work always looks a little wrong)
Doing it your self is possible with a knee kicker and a carpet knife.
Rusty Baker is a carpet guy---I hope he sees this.----Mike---
Old 05-29-2011, 07:39 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
Ir's doable, but not easy for a DIYer. Laying it back and putting the wood down, no problem. Stretching the carpet back without a wrinkle can be tough, if you aren't a pro. Probably better to see what an installer would charge to put the carpet back. Here it would most likely run $50-$75. Probably run that much to rent the tools.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
oh'mike (05-29-2011)
Old 05-29-2011, 07:57 PM   #4
DIY staff
Well said,Rusty. I refer a lot of business to my carpet man----Good installers are able to make a modification like that look like it was always there.----I don't even like to make a simple doorway to transition .--Mike---
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 09:31 AM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 10:20 AM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
Damaged Section of Hardwood jelder Flooring 6 08-09-2006 10:24 PM
