Hardwood Sanding - Flooring - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 12:53 AM   #1
toolbelt Tina's Avatar
Hardwood sanding
I am about to finish installing 1200 sq ft of mixed red white oak in the cottage.
The hardwood is of utility and rustic grades and contained black knot holes. What do I use as a filler ? Same color? Apply filler first or after sanding.
Some boards were splits and have fine open lines 1/16 to 1/8 at most extreme, what do I use to fill these in?
The hardwood was unfinished, what grit will I be starting with? I have been reading 24-36 but those are for finished floors.
How many belts should I get? And generally what are rental rates?
Thanks for tips from the experts as always.
Tina
toolbelt Tina is offline   Reply With Quote
Old 05-26-2011, 05:02 PM   #2
woodman58's Avatar
Here is a link that might help.
http://www.finishingwoodfloors.com/f...es/manual.html
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
toolbelt Tina (05-26-2011)
Sanding methods for uneven hardwood floors inquisitiveblue Flooring 3 08-05-2011 11:49 AM
Removing glue from hardwood floors - sanding? jbitt Flooring 2 01-20-2010 06:10 PM
Hardwood floor "stains" after sanding moeseegs Flooring 1 10-03-2009 11:01 AM
Rotating Sanding Marks on Hardwood floor Msmtee Flooring 2 07-24-2009 08:06 PM
old hardwood on it's last sanding glover10604 Flooring 1 09-09-2008 05:38 PM
