Old 08-18-2011, 09:36 PM   #1
RR.
Hardwood repair - Radiator pipe holes
My 1930's house had radiators at one point but was switched to baseboard before I moved in but I still have the holes to prove it
I have about 13 of these holes, at least one in every room. What is my best bet, cut out the board and replace? Can anyone provide any more detail in this process, I don't have any previous experience in flooring.
RR. is offline   Reply With Quote
Old 10-30-2011, 03:16 PM   #2
RR.
Still on my to-do list and I still could use some help getting started if anyone has any suggestions.
Old 10-30-2011, 03:33 PM   #3
Super Moderator
Exactly how far is the damage from the base board?
From base board to edge of hole----
The reason I ask is there is a nice patching method using a router--but you may be to close to the baseboard to get a router in there.
Old 10-30-2011, 03:35 PM   #4
RR.
I have 10+ holes, they vary from 1-4" from baseboard.
Old 10-30-2011, 03:35 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Do you have any pieces that you can steal from a closet?
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 10-30-2011, 03:38 PM   #6
RR.
And make plugs? I could do that but I'd rather not turn a closet into swiss cheese if there is another way.
Old 10-30-2011, 04:10 PM   #7
Super Moderator
I don't have time to get into a long explanation right now---but look up 'router inlay' on you tube---
I use that to remove knots in a board and patch--also for insetting brass electrical floor outlets.
Done correctly ,the patch is seamless (and fast)
Trouble is a standard router has a setback of 2 1/2" --your holes are a bit to close.
Perhaps a small trim router could work--I don't know if the rub collars required are available for a trim router.
Jiju is an old hand with a router--Hpoefully he will know.
Old 10-30-2011, 08:34 PM   #8
the process is pretty simple. Tape off the surrounding boards so as not to damage them. you will need a 1" spade bit, cordless drill/power drill and circular saw with sharp blade. take spade bit and drill holes along the length of the damaged boards. stop about 1" from ends of boards. take circular saw with sharp blade, set depth to 3/4" and cut multiple lines in damaged boards. stop saw 1" from ends of boards. use chisel to take out strips and carefully remove rest of board. take your time and go slow. the nails and/or staples from initial installation should appear. take pliers and pull them out. if you reply , i will tell how how to install new boards.
acglobal is offline   Reply With Quote
Old 10-30-2011, 08:45 PM   #9
I would plug the holes, like oh' mike said. I have plugged hardwood in my woodworking shop and the plugs were almost invisible.
The Following User Says Thank You to rusty baker For This Useful Post:
oh'mike (10-31-2011)
wood dowels good for repair bad screw holes? darsunt Carpentry 10 08-12-2011 07:42 AM
Patching vinyl siding to "repair" small holes tomseeley Building & Construction 3 06-05-2011 10:12 AM
Hardwood over OSB & transition issue janralix Flooring 4 05-03-2011 12:29 AM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 11:20 AM
Hardwood floor duct opening repair gshock Carpentry 4 07-29-2007 12:57 AM
