Hardwood Reducer To Vinyl Using Elastilon - Flooring - DIY Chatroom Home Improvement Forum
Old 06-26-2012, 06:12 PM   #1
Rewards Points: 33
Hardwood reducer to vinyl using elastilon
I have to install a reducer (from 3/8 hardwood to vinyl) under the door. I am using elastilon to install my floor, over concrete. I will have to cut the last piece so that the reducer sit right under the door which mean there will be no tongue to glue it with the reducer.
Will wood glue strong enough to hold the last piece with reducer? I am thinking of having half of the reducer sit on elastilon and the other half glue on the vinyl (using construction adhesive).
Can you please advice?
cfreak is offline   Reply With Quote
Vinyl tile over hardwood removal twostuds Flooring 0 06-12-2012 10:19 PM
Glue Down Hardwood on Vinyl Tiles thone Flooring 6 07-27-2011 07:54 AM
Hardwood to Vinyl step alstan Flooring 1 12-06-2010 08:50 AM
Vinyl Tile Over Hardwood LGrey Flooring 1 02-16-2009 10:34 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
