Hardwood Questions - Flooring - DIY Chatroom Home Improvement Forum
Old 12-30-2012, 03:48 PM   #1
Rewards Points: 528
hardwood questions
Which method is recommended for installing 3/8"engineered hardwood over wood subfloor,the flooring adhesive technique or the staple/nailer technique?
Also is the tongue side to be facing room ,ive seen both directions mentioned online.
And isnt the felt to be laid in the same direction as the flooring- with the joists,Ive seen it mentioned both ways, again.
Thanks for any info.
hidden1 is offline   Reply With Quote
Old 01-01-2013, 04:45 PM   #2
Rewards Points: 528
I can use either option from manufacture specs .
I guess ill just use the nailer option with the felt running in same direction .Will nail thru the tongue edge(after 2nd or 3rd row).And run it in same direction as hallway /kitchen floor since it will be right at hallway.
Old 01-02-2013, 06:03 PM   #3
Rewards Points: 264
I would staple it. It will feel more solid to walk on. I prefer the bostich staplers like this for engineered http://www.newegg.com/Product/Produc...-pla-_-NA-_-NA. Hope this helps.
Awoodfloorguy is offline   Reply With Quote
Old 01-08-2013, 10:31 PM   #4
I agree .. Staple it , If you glue it will not have a vapor paper , Unless you coat the floor with a vapor retarder , Glueing is usually for concrete , Stapleing is way easier to repair than glue down
tacomahardwood. is offline   Reply With Quote
Old 01-09-2013, 11:17 AM   #5
this is a good deal, i bought their nailer for 3/4 inch hardwood and worked great on the 3 rooms i have done so far and its 100.00 dollars than the bostich. HD was selling freeman products.
http://www.amazon.com/Freeman-PFBC94.../dp/B004FP99GC
it comes with a 7 year warranty too
hardwood refinishing questions NateHanson Flooring 3 07-12-2011 11:21 PM
questions about best way to level sub-floor for hardwood installation cbendock Flooring 4 12-08-2010 06:48 AM
questions about 20 year old hardwood flooring uper104 Flooring 2 10-09-2007 11:54 AM
Questions on Staining Hardwood! noodlesalad Flooring 2 12-15-2006 10:17 AM
Hardwood floor questions KUIPORNG Flooring 4 11-09-2006 09:08 PM
