Old 04-25-2009, 09:56 PM   #1
Hardwood over OSB & transition issue
I have a 35 year old house & want to replace carpeting with 3/4" solid T&G oak hardwood (3-4"). The area involved is about 650 square feet (3 bedrooms & a hallway).
(1) The floor under the carpet appears to be OSB, but may be particle board. Whatever it is, it is on top of plywood & is very solid. Assuming (a) the floor surface is OSB, can the hardwood be installed (nailed or stapled, whichever is proper) directly on the OSB? If not, what has to be done to use the hardwood, or should I consider another wood flooring product? Assuming (b) the floor is particle board...same questions.
(2) Assuming I can install the hardwood directly over the existing floor, one end of the hallway (about 3.5' wide) will butt up against an existing slate floor. The problem here is that the slate is only about 1/4" above the sub-floor, so the 3/4" hardwood will be at least 1/2" higher than the slate. I know there are transition pieces, but are they available, & will they work & look well, for such a height difference?
Thanks for any advice.
janralix is offline   Reply With Quote
Old 04-26-2009, 07:55 AM   #2
Over OSB, yes, over particle board, never.
Old 04-26-2009, 10:05 AM   #3
Concrete & Masonry
Like Bill said, & take a look at the subfloor cross section (at heat vent, stairwell, any other holes in floor) to see if the particle is just underlayment. If you have at least 5/8" ply under particle, remove it and have no change on height to the slate.
jomama45 is offline   Reply With Quote
Old 04-27-2009, 02:24 AM   #4
Thanks you two...that helps.
I have determined I have OSB over plywood so I'm assuming I'm good to go with the solid 3/4" hardwood.
Now, assuming I don't want to go to the trouble & expense of ripping out the OSB, I still have the issue of the hardwood being 1/2" higher than the slate it will butt against at the end of the hall.
My main question is now is that 1/2" transition too high to try to overcome with a transition piece? In other words, is a 1/2" height difference too much to try to transition with a 2" or so wide transition piece so as to eliminate any tripping point?
If it is, what other options, if any, do I have?
Thanks...
More On This Topic
We spend more time in the bedroom than most other rooms in the house on a daily basis. Keeping the bedroom as dust free as the rest of the house should be a high priority. Spending time each day or once a week cleaning the bedroom can make a big... Read More »
Isolation in your recording studio needs to be at the front of your mind. Improper isolation will result in rumble, bleed and unwanted resonance in your recordings. One of the places you need to consider isolation is in your floor. Rumble and vibrations... Read More »
If your child attends a Montessori school, you might find yourself having to explain the Montessori Method of Education to your family and friends. Because most people attended traditional schools, they have a hard time understanding why you would choose... Read More »
Hi! I’m Tad Donley and I’m speaking in behalf of Expert Village. I’m giving you tips on how to make your own recording studio. Hardwood floors, let me tell you about that, I would be wary of hardwood floors, it is the mirror effect that... Read More »
Wood floorings are beautiful alternatives to carpet and tile in the home. They are easy to clean and look nice. However, it is important to maintain wood floors properly. Read on to learn more. Read More »
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 12:21 PM
Hardwood Floor to stone Transition - how? water_cutter101 Flooring 3 03-05-2009 05:51 PM
Hardwood to tile transition DIY-Renovator Flooring 3 07-06-2008 02:44 PM
Transition from Tile to Hardwood anthony9887 Flooring 1 04-19-2008 12:51 AM
Hardwood and Tile Transition Gap mobowhunter Flooring 2 01-19-2008 06:25 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
