Old 10-05-2012, 12:05 AM   #1
Hardwood Over Concrete Slab
What is the best method to install 3/4 pre-finished hardwood over a concrete slab that was once a garage floor? The slab is not in a basement.
iplay1515 is offline   Reply With Quote
Old 10-05-2012, 01:17 AM   #2
I would suggest floating a layer of 3/4" plywood on the concrete. Then add a 2nd layer of 3/4" ply and be sure to stagger the joints and screw this layer into the one below it. Then lay down some roofing felt paper and staple the floor to the plywood using 1.5" crown staples.
Awoodfloorguy is offline   Reply With Quote
Old 10-05-2012, 07:00 AM   #3
No disrespect meant but, But not a great plan.
Wood should never be in direct contact with concrete unless it's pressure treated. And no pressure treated plywood in this case is not the ansewer!
A whole lot easyer to lay a layer of vaper barrier and use engineered flooring and install it as a floating floor by gluing all the seams.
You would have the same look and feel, could still be refinished at some point, and still have real wood as a top layer.
Engineered flooring is below grade rated (yes I read where your not below grade but it's nice to use a product you know will not be effected)
Old 10-05-2012, 07:05 AM   #4
Plastic film doesn't glue very well. What would be alternative vapor barriers for this application?
Does the engineered product "snap" or lock together?
Old 10-05-2012, 07:11 AM   #5
If you lay the floor the way I suggested the 6 mil. os just layed on the slab, seams get taped, and flooring is just laid down over it. The only glue used is on the seams, not under it gluing it to the plastic.
It's done this way all the time in basements.
In one of my rentals I layed the 6 mil. then 3/4 blue foam panels on the slab before the engineered flooring to act as a thermal break.
Now the floor feels warmer, a the floor does not flex or move at all.
Old 10-05-2012, 07:20 AM   #6
What is the best tape to use on the seams?
Some blue foam panels have foil on one side. Any opinion on this?
Old 10-05-2012, 07:29 AM   #7
The same tape that's used on Tyvek house wrap will work.
I've never seen dence blue foam with foil on it but if there is I'd have it facing up.
Before doing anything take a look at some of the manufactures web site that make engineered flooring and take a look at the hundred or so differant type of wood avalible and also look at there install directions so you have a complete understanding.
Old 10-05-2012, 08:28 AM   #8
You do not say where you are and I think that makes a diff. I am in fla. so everything is built on a concrete slab. So if the garage was poured at the same time it's probably the same thickness. If you are up north and have a basement a lot of times the garage floor is thinner than a slab. My suggestion would be to take couple places, tape down a piece of pretty heavy plastic (make sure it's sealed around the edge) let it set a couple days. Then remove and see if it is wet under the plastic. Depending on if it is wet or how wet it is you may have to explore other options.
Old 10-05-2012, 09:22 AM   #9
Thanks. I live in Southern Pines NC. Will do the moisture test next week and report back.
The main house was built on a crawl space in 1974. No moisture problems under the house.
Old 10-05-2012, 10:02 PM   #10
Tileguy
JazMan's Avatar
Iplay,
There's all type of non-approved methods that individuals claim work well, some don't. Although some of these methods may work sometimes, they are not approved for a reason, they sometimes fail. Plastic on a slab is one that can bite you. What does the wood manufacturer say? What brand is it?
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 10-05-2012, 10:04 PM   #11
Originally Posted by JazMan View Post
Iplay,
There's all type of non-approved methods that individuals claim work well, some don't. Although some of these methods may work sometimes, they are not approved for a reason, they sometimes fail. Plastic on a slab is one that can bit you. What does the wood manufacturer say? What brand is it?
Jaz
I sent an email to the mfg. today on this matter. Thanks.
Old 10-06-2012, 10:52 AM   #12
Iplay,
Jaz
How would you suggest to check for moisture in a slab? This is what I was taught and what I read but am interested in a better way.
Old 10-06-2012, 05:32 PM   #13
I uses a moisture meter on wood, but not sure it would indicate a valid result with impenetrable concrete.
Possibly a block of wood could be measured, then place on the concrete and measured again in a few days. An increase would suggest moisture, but making a valid quantitative interpretation may be difficult.
I like the poly film idea myself for at least a rough indicator.
Is there a sealer that can be applied to concrete to eliminate the issue?
Old 10-06-2012, 05:54 PM   #14
I was hoping Jaz would come back to tell us another way and i'm pretty sure he will. And yes the poly was only ever a rough indicator. And yes there are concrete sealers but i'm not sure they are for this application. Maybe someone else knows for sure.
Old 10-06-2012, 05:57 PM   #15
Pro Flooring Installer
rusty baker's Avatar
http://www.concreteconstruction.net/...te-floors.aspx
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
ToolSeeker (10-06-2012)
Lay plastic between ground and concrete slab? Flt_Simulation Flooring 8 04-22-2012 06:56 AM
Hardwood flooring over concrete? Cobrakillert Flooring 8 10-31-2011 10:02 PM
Supporting Concrete Slab from Underneath? Yippydadada Building & Construction 5 10-18-2011 05:24 AM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 06:14 PM
