Hardwood Over Concrete Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 06-14-2012, 06:56 PM   #1
Hardwood over concrete slab
Hi
(Re-posting as a new topic.)
I want to install hardwood (American walnut, 3/4" by 4") in my condo and I have a concrete slab. I have done some research on various sites, so I have read about the old recommended methods that used asphalt, as well as some more recent methods that use two layers of plywood. I have also read a lot about hardwood not being recommended on a concrete slab by some people.
Here is the procedure I have come up with after doing my research. I would like to hear some opinions before I start.
First, I will put a layer of polyethylene sheet, 6 mil, on the concrete slab, as a moisture barrier.
Second, I will put two layers of 3/8" plywood, with the individual sheets staggered. The bottom layer is CDX. The top layer is similar but the upper face is sanded (it costs slightly more but will probably make the work a little easier). I will staple or screw the two layers of plywood together, taking care not to puncture the underlying polyethylene sheet. The two layers of plywood will cover the entire room as if they were a single large, heavy block, floating over the slab. The plywood will not be nailed to the concrete.
Finally, I will nail the hardwood to the plywood using 1-1/2" L-cleats.
Comments?
alessandrot is offline   Reply With Quote
Old 06-14-2012, 09:55 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
Sounds like a terrible idea to me. What does the manufacturer say about this type of installation? It almost always is a bad idea to attempt 3/4" hardwood when concrete is involved.
Jaz
Old 06-14-2012, 10:08 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 124
Moisture will accumulate under the plastic and grow mold.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 06-14-2012, 10:13 PM   #4
For going over concrete this is the method for solid hardwood. It sounds like you have it pretty well figured out.
RhodesHardwood is offline   Reply With Quote
The Following User Says Thank You to RhodesHardwood For This Useful Post:
JetSwet (06-15-2012)
Old 06-15-2012, 05:05 AM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
Defiantly get the product recomendations 1st.
Is this a raised slab? Get a moister test done 1st.
I wouldn't use cdx, maybe advantech T&G but not 2 sheets you might as well just raise the floor with pressure treated 1x4s then your ply.
JetSwet is offline   Reply With Quote
Old 06-15-2012, 05:35 AM   #6
Rewards Points: 13,732
Use engineered flooring instead!
Look into it, it's even below grade rated, far more stable then soild wood, same look because it's real wood on the surface, can be refinished.
Old 06-15-2012, 07:12 AM   #7
JetSwet:
Thanks for the advice.
To answer your question, the top surface of the slab is one foot above grade (not less).
What's wrong with using two sheets of plywood? Using 1x4s would raise the floor even more and would require more work than using a second layer of 3/8" plywood. Also, if I used 1x4s, where do you suggest I should put the plastic sheet?
Old 06-15-2012, 07:32 AM   #8
Pro
JetSwet's Avatar
Rewards Points: 502
Originally Posted by alessandrot
JetSwet:
To answer your question, the top surface of the slab is about 1 to 2 feet above grade.
Forget about what I said I was giving idea if u were below the grade.
If your that high off the grade you will be fine with your plan.
Just put one layer of ply down your angled nails go in on a angle not straight down.
Old 06-15-2012, 07:51 AM   #9
JetSwet:
Thanks. If I understand your picture correctly, the plastic sheet goes between the concrete and the plywood and the roofing felt goes between the plywood and the hardwood, right? I had not considered the roofing felt, but I will certainly add it if it's useful.
Old 06-15-2012, 08:45 AM   #10
Pro
JetSwet's Avatar
Rewards Points: 502
JetSwet:
Yes that exactly how it goes. You got it!
Old 06-15-2012, 01:40 PM   #11
Rewards Points: 124
Pressure treated lumber is never to be used indoors.
Old 06-15-2012, 02:15 PM   #12
Rewards Points: 1,596
I would follow the instructions from the mfg before I did anything to see what they recommend so the warranty will be supported. Otherwise, you are on your own if something does south.
bob22 is offline   Reply With Quote
Old 06-15-2012, 02:41 PM   #13
Pro
JetSwet's Avatar
Rewards Points: 502
Oh please. It's fine if your worried about termites can go with the borate lumber but this option is ruled out anyway.
Old 06-15-2012, 07:56 PM   #14
By doing it your way your going to throw off every baseboard, door opening, and where it meets any other flooring.
Why in the work would use you 2, Layers of 3/8's. If you insist on doing it your way use 3/4" Advantec sub flooring.
Old 06-15-2012, 08:13 PM   #15
Pro
JetSwet's Avatar
Rewards Points: 502
Advantech yes but I dont even think 3/4" is necessary. 1/2"?.... Although the nails might not hold so your right Joe. Nevermind lol
Lay plastic between ground and concrete slab? Flt_Simulation Flooring 8 04-22-2012 05:56 AM
Hardwood flooring over concrete? Cobrakillert Flooring 8 10-31-2011 09:02 PM
Supporting Concrete Slab from Underneath? Yippydadada Building & Construction 5 10-18-2011 04:24 AM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 05:14 PM
