-   -   Hardwood over concrete slab (http://www.diychatroom.com/f5/hardwood-over-concrete-slab-147065/)
alessandrot 06-14-2012 06:56 PM
Hi
(Re-posting as a new topic.)
I want to install hardwood (American walnut, 3/4" by 4") in my condo and I have a concrete slab. I have done some research on various sites, so I have read about the old recommended methods that used asphalt, as well as some more recent methods that use two layers of plywood. I have also read a lot about hardwood not being recommended on a concrete slab by some people.
Here is the procedure I have come up with after doing my research. I would like to hear some opinions before I start.
First, I will put a layer of polyethylene sheet, 6 mil, on the concrete slab, as a moisture barrier.
Second, I will put two layers of 3/8" plywood, with the individual sheets staggered. The bottom layer is CDX. The top layer is similar but the upper face is sanded (it costs slightly more but will probably make the work a little easier). I will staple or screw the two layers of plywood together, taking care not to puncture the underlying polyethylene sheet. The two layers of plywood will cover the entire room as if they were a single large, heavy block, floating over the slab. The plywood will not be nailed to the concrete.
Finally, I will nail the hardwood to the plywood using 1-1/2" L-cleats.
Comments?
JazMan 06-14-2012 09:55 PM
Sounds like a terrible idea to me. What does the manufacturer say about this type of installation? It almost always is a bad idea to attempt 3/4" hardwood when concrete is involved.
Jaz
rusty baker 06-14-2012 10:08 PM
Moisture will accumulate under the plastic and grow mold.
RhodesHardwood 06-14-2012 10:13 PM
For going over concrete this is the method for solid hardwood. It sounds like you have it pretty well figured out.
JetSwet 06-15-2012 05:05 AM
Defiantly get the product recomendations 1st.
Is this a raised slab? Get a moister test done 1st.
I wouldn't use cdx, maybe advantech T&G but not 2 sheets you might as well just raise the floor with pressure treated 1x4s then your ply.
joecaption 06-15-2012 05:35 AM
Use engineered flooring instead!
Look into it, it's even below grade rated, far more stable then soild wood, same look because it's real wood on the surface, can be refinished.
alessandrot 06-15-2012 07:12 AM
JetSwet:
Thanks for the advice.
To answer your question, the top surface of the slab is one foot above grade (not less).
What's wrong with using two sheets of plywood? Using 1x4s would raise the floor even more and would require more work than using a second layer of 3/8" plywood. Also, if I used 1x4s, where do you suggest I should put the plastic sheet?
JetSwet 06-15-2012 07:32 AM
1 Attachment(s)
Originally Posted by alessandrot
JetSwet:
To answer your question, the top surface of the slab is about 1 to 2 feet above grade.
Forget about what I said I was giving idea if u were below the grade.
If your that high off the grade you will be fine with your plan.
Just put one layer of ply down your angled nails go in on a angle not straight down.
Attachment 52456
alessandrot 06-15-2012 07:51 AM
JetSwet:
Thanks. If I understand your picture correctly, the plastic sheet goes between the concrete and the plywood and the roofing felt goes between the plywood and the hardwood, right? I had not considered the roofing felt, but I will certainly add it if it's useful.
JetSwet 06-15-2012 08:45 AM
JetSwet:
Yes that exactly how it goes. You got it! :)
rusty baker 06-15-2012 01:40 PM
Pressure treated lumber is never to be used indoors.
bob22 06-15-2012 02:15 PM
I would follow the instructions from the mfg before I did anything to see what they recommend so the warranty will be supported. Otherwise, you are on your own if something does south.
JetSwet 06-15-2012 02:41 PM
Oh please. It's fine if your worried about termites can go with the borate lumber but this option is ruled out anyway.
joecaption 06-15-2012 07:56 PM
By doing it your way your going to throw off every baseboard, door opening, and where it meets any other flooring.
Why in the work would use you 2, Layers of 3/8's. If you insist on doing it your way use 3/4" Advantec sub flooring.
JetSwet 06-15-2012 08:13 PM
Advantech yes but I dont even think 3/4" is necessary. 1/2"?.... Although the nails might not hold so your right Joe. Nevermind lol
