Hardwood Over Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 12-06-2008, 03:42 PM   #1
Hardwood over concrete
I have a 50 year old above grade concrete floor I am looking to put 3/4 hardwood flooring over. It has 1/2 sound board with 1/2 durock laid on top. I was thinking of screwing plywood to the durock then nailing the flooring to this. What do you think? Peter
robothouse is offline   Reply With Quote
Old 12-07-2008, 08:20 AM   #2
i would altho i don't know how ' sound board ' is defined,,, t&g 3/4" plywood screwed thru to the sub-floor, too !
yesitsconcrete is offline   Reply With Quote
Old 12-07-2008, 08:30 AM   #3
It is foam on both sides of a honeycomb cardboard product. Both layers are floating at this point. Peter
Old 12-07-2008, 09:42 AM   #4
thanks, pete,,, doesn't change what i'd do,,, we've got roofing paper under our 3/4" maple flooring,,, yours sounds better to me.
Old 12-07-2008, 01:02 PM   #5
So here is the short of it: 50 year old concrete floor, an old JC Penny building. Floated on this is 1/2" soundboard. Floated on this is 1/2" Durock. Screwed to this I will install 3/4" plywood on the 45 degree with roofing paper next. Nailed to this will be the 3/4" hardwood. Does this about do it or do I take the Durock up and sell it and pour a concrete floor and glue the 3/4" hardwood to this?
Old 12-07-2008, 10:27 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 240
How are you planning to screw to the Durock and this sound board? Those product won't take a screw. You'd be able to remove the screws with your fingers. Not a good plan there.
I don't understand why there is Durock on this floor in the first place. Durock, and all CBU's are intended to be thinseted and fastened to wood floors, not just bonded as this must be.
If this substrate has been down for years and is still OK, why don't you install engineered wood? Engineered can be glued or just floated loose.
Solid 3/4" hardwood must be nailed to wood substrates. There are methods to do this over concrete, but the Durock and cardboard honeycomb stuff has to go.
What brand hardwood are you considered or have you chosen one yet? Each manufacturer has specific instructions, especially when a non-standard method is considered. Be sure to read the fine print and when instructions seem vague.
Jaz
Old 12-08-2008, 09:09 AM   #7
Jazman, Thanks for the comment. The soundboard is floated, it is more of a cardboard, and it needs to stay for sound purposes. The durock is also floated and is also for sound purposes. All others but one build left this as is, installed underlayment, then a floating floor, tile or carpet. One guy took up the durock and poured a layer of concrete and installed hardwood flooring on that. I am not sure if it is engineered or solid. Peter
recommended subflooring for hardwood on concrete slab blackcat Flooring 5 10-26-2008 06:15 PM
OLD Hardwood ( maple ) on a concrete slab MrLinux Flooring 1 01-31-2008 10:47 PM
Hardwood over concrete slab El Buey Flooring 9 08-02-2007 08:42 AM
Hardwood over Concrete SpunFree Flooring 6 07-09-2007 03:21 PM
Hardwood in kitchen over concrete slab Markvonjinn Flooring 12 05-09-2006 10:37 AM
