Hardwood And Laminate Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 09:16 AM   #1
Hardwood and Laminate Transition
I currently have an open floor plan on the first floor (between the kitchen and living room), with laminate in the kitchen area and carpet in the living room. We want to replace the carpet and put in solid hardwood, but I am concerned that it will clash with the laminate since they will be up against each other. I've read that I am better off not trying to find a a match because unless it's a perfect match, it will look shabby. So I would be better off choosing a totally different color. However, all of the trim (baseboard, staircase, window trim, etc.) in the living room matches the laminate. Was hoping to get some advise on what I should do? I'm not sure I can find a perfect match with the current laminate, and I'm not sure if I should be concerned with trying to match both color and grain pattern?
And sort of related to this, should the hardwood color match the color of your door, baseboard and window trim?
Thanks!
seanf12 is offline   Reply With Quote
Old 01-14-2010, 01:11 PM   #2
Flooring Supply Shop
motti's Avatar
solid/Laminate
Hi
The connection between the solid and the laminate will never be 100% color and grain pattern match, but it is still look good if it will be in a deferent rooms,
My opinion is that the baseboard is not have to be the same color as the floor,
About the doors and windows trim I think It will be nice if it will match.
You didnít say what is the color you trying to match (that way we can help you to find it) if you have picture that will help
Jack73
motti is offline   Reply With Quote
Old 01-14-2010, 02:34 PM   #3
Thanks for the response
This is the exact floor we have from Shaw's
http://www.shawfloors.com/laminate-f...t-Autumn_Maple
The wood trim around the windows and doors is very close to this color.
Laminate & hardwood in the same room, good or bad idea?? phatjoe Flooring 10 05-14-2011 10:57 PM
Dupont Laminate Hardwood Flooring Huntz Flooring 3 08-29-2009 02:35 PM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 10:01 AM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 09:43 PM
Flooring hardwood v engineered or laminate skits Flooring 1 07-12-2006 10:03 AM
