Hardwood Laminate On Moist Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 06-22-2010, 01:39 PM   #1
Hardwood Laminate on Moist Slab
First-time poster, and first-time homeowner here, so be gentle:
I'm getting ready to install 12mm hardwood laminate on concrete slab, and had a subfloor moisture test done. The test came back at 13%; the contractor doing the testing said that over 4% would require a liquid moisture barrier be put down prior to installation.
A few questions:
-I've had one person tell me that up to 18% is acceptable, and that a normal moisture barrier is sufficient in my case. Is this true or false?
-If a liquid moisture barrier is needed, what am I looking at pricewise/laborwise if I apply it myself? The contractor today suggested I would have to contract it out at great expense.
-Lastly, what are your recommendations for a liquid moisture barrier?
Thanks in advance for the help!
Pfmohr1 is offline   Reply With Quote
Laminate & hardwood in the same room, good or bad idea?? phatjoe Flooring 10 05-14-2011 10:57 PM
Basic questions for hardwood or laminate install Demus Flooring 3 01-17-2010 07:38 PM
Hardwood and Laminate Transition seanf12 Flooring 2 01-14-2010 02:34 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 09:43 PM
