Old 05-04-2006, 07:05 PM   #1
Hardwood in kitchen over concrete slab
I have plans to install a Brazilian Teak engineered hardwood floor in my kitchen which is a concrete slab. I live in California (Simi Valley), so I'm not too concerened with extreme shifts in weather. I have removed all of the cabinets and was wondering what is the best way to install the floor. Can I glue it directly to the slab, or do I need to put down a subfloor and if so, how do I go about doing that?
Markvonjinn is offline   Reply With Quote
Old 05-04-2006, 07:27 PM   #2
Floorwizard's Avatar
make sure the floor is flat and level according to manufacturer specs.
install a 6 mil poly over the slab.
float the wood over the top of the poly.
make sure you install cabs first.
good luck
Floorwizard is offline   Reply With Quote
Old 05-04-2006, 08:18 PM   #3
Tileguy
Bud Cline's Avatar
This flooring comes in slats, right? Do you glue the slats together?:confused:
Old 05-05-2006, 11:10 AM   #4
Yes, the flooring comes in slats with a tounge-in-groove assembly. They are not, however inter-locking like a pergo floor
Old 05-05-2006, 04:11 PM   #5
Long-Time DIYer
Mike Swearingen's Avatar
I don't know how thick this flooring is, but be careful not to trap the dishwasher.
Sometimes adding tile, wood flooring, etc. will build the floor up enough so that a dw can't be removed from a fixed cabinet base, and then the flooring has to be cut out in order to remove and replace it.
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-05-2006, 06:17 PM   #6
How thick are the slates?
Some floors are nailed, some are glued together and some interlock.
Did the floor come with instructions?
It sounds like that the floor may be the type that is nailed.
redline is offline   Reply With Quote
Old 05-05-2006, 06:19 PM   #7
Does the manufacturer have an 800 number that you could call and ask if you can glue this floor together or does it have to be nailed?
Old 05-05-2006, 11:00 PM   #8
An engineered can be glued, floated, or nailed.
Old 05-06-2006, 04:50 PM   #9
Tileguy
Bud Cline's Avatar
"Nailed" to a concrete slab?
Old 05-07-2006, 08:13 PM   #10
no, but nailed to plywood installed over slab
Old 05-08-2006, 01:11 PM   #11
Tileguy
Bud Cline's Avatar
......and how is the plywood attached to the slab?
Old 05-08-2006, 10:23 PM   #12
Glued
Old 05-09-2006, 10:37 AM   #13
Tileguy
Bud Cline's Avatar
I'm learning here......bear with me.
When glueing full sheets of plywood to a concrete slab how would one get all of the edges of the plywood to flush-up on the surface while the glue is setting-up? Of course if the concrete was perfectly plane this wouldn't be an issue but how often does one see a "perfectly plane" concrete slab? So.....how is this done?
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
Hardwood over concrete slab El Buey Flooring 9 08-02-2007 08:42 AM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 06:14 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
