Old 12-25-2012, 01:35 PM   #1
hardwood installation
In my 50s ranch there is 3/4"x6" wooden planks on top of the 2x10 joists 16"OC.
Then there are some 3/4" wooden strips on top of the planks. Then there is the 3/4" hardwood.
I hope this makes sense.
Directly over joists: 3/4" x 6" wood planks; 3/4" strips; 3/4" hardwood
Where the is no joist: 3/4" x 6" wood panks; 3/4" air gap; 3/4" hardwood
The house has a crawl space and maybe they did this to create an air insulation zone?
So basically the hardwood is supported only where the strips are. There is an airgap where there is no strips. The strips are placed directly over where the joists are.
So I want to install hardwood in the kitchen.
Should I follow the same technique?
Or should I skip the strips and just add plywood over the 3/4"x6" strips?
john_bry is offline   Reply With Quote
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 08:37 PM
Dimples in New Hardwood Installation tommy99 Flooring 20 12-28-2011 01:26 AM
Hardwood flooring installation - Should these planks not be installed? htabbas Flooring 8 11-30-2011 08:50 PM
Winter hardwood installation joemontana16 Flooring 2 02-10-2010 07:01 PM
hardwood flloring installation bannasch Flooring 1 07-19-2008 01:44 AM
