-   -   Hardwood has a subfloor on top that I would like to remove (http://www.diychatroom.com/f5/hardwood-has-subfloor-top-i-would-like-remove-19282/)
capslock 03-31-2008 07:33 AM
Hello,
I just discovered that I have redwood hardwood flooring in my kitchen. Actually there are two types I believe but I am not sure 100% at the moment.
The previous owner we came to find placed a subfloor on top of the kitchen hardwood floor.
We were going to place a cork floor in but now that we discovered the hardwood we will be going to use that floor instead.
However this is where I come here to ask you questions. The subfloor had been I guess glued to the hardwood. There is a black "matting" underneith the sub floor that is extremely tedious ro remove as it is bound by adhesive if I had to guess.
So, what would you suggest I use to remove the adhesive from the hardwoord flooring?
Removing the sub floor is easy, its this stuff thats glued to the floor thats a problem. Thanks for any tips and your time :)
Floorwizard 03-31-2008 09:13 PM
goodness.
worst case.....never will happen. scrape and destroy, then sand the heck out of it until all gone.
no miracle here.
capslock 03-31-2008 09:42 PM
hmm...so you are saying that there is no solvents that can remove adhesive off of a hardwood floor?
Floorwizard 04-01-2008 10:27 AM
bostics best makes an adhesive remover safe for urethane floors. but that may be too weak and you are not going to save the urethane.
I am sure there is acetoneor thinner as well.
in the end you will need to sand anyway, so possibly you could let the sanding do all the work.
