Hardwood To Hardwood Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 04-13-2013, 08:17 AM   #1
Rewards Points: 95
Hardwood to hardwood transition
I'm about to embark on a total second floor makeover. Replacing all the carpet with hardwood.
My plan is to use all 3/4" hardwood so the transitions from main room to bedrooms can be continuous. However, I don't plan on using the same color/species of wood in every room.
I've thought of three ways to transition from floor to floor:
1. Slide one wood in to the other
2. Use a transition between the woods
3. Use a totally different shade of wood between the two woods
My original thought was to use the same thickness throughout so I could just continue installing the next wood into the previous wood at each doorway. Is this a good practice? What would a professional do?
Brad Nailer is offline   Reply With Quote
Old 04-13-2013, 08:29 AM   #2
Rewards Points: 13,300
If all the wood is the same thickness you would use a spline where the to connect.
http://www.woodfloorinstallationguid..._a_Spline.html
Old 04-13-2013, 12:06 PM   #3
Rewards Points: 258
Asthetics is a matter of taste. Were it me, I would choose number three with a transition piece of a different type of wood at the entrance to each door. Since you won't be using a great deal of the transition wood it could be something exotic or expensive.
Being human is the result of heredity.
Being humane is a matter of choice.
retired guy 60 is offline   Reply With Quote
Old 04-13-2013, 11:29 PM   #4
Rewards Points: 95
This is what I was thinking. We can get samples for $5, no matter that type it is. So why not get something really cool looking for $7.50/sq ft, for example, and use it as the transition?
Suggestions for transition between old hardwood and new hardwood evaluator Flooring 2 08-14-2012 04:16 PM
Hardwood over OSB & transition issue janralix Flooring 4 05-03-2011 12:29 AM
hardwood to ceramic no transition strip alaus24 Flooring 2 11-30-2010 10:53 AM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 11:20 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 12:21 PM
