Hardwood Glued Directly To Raidiant-heat Slab?? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-12-2008, 11:02 AM   #1
Post
Hardwood glued directly to raidiant-heat slab??
I have about 1300 ft of hardwood to put down and I have a slab with radiant heat (hydronic tubes embedded in slab). Has anyone done this without first putting down a wood subfloor? I found a glue that is recommended specifically for hardwood to radiant concrete substrate. Any sugggestions will be much appreciated! I'm in NM and humidity shouldn't be an issue.
High Desert Man is offline   Reply With Quote
Old 01-13-2008, 01:27 PM   #2
What is the temp that the radiant is set at?
redline is offline   Reply With Quote
Old 01-13-2008, 03:55 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 340
Hi High,
You say hardwood, so I assume it's 3/4" solid as apposed to engineered hardwood? If that's the case my answer is no. The traditional 3/4" has to be nailed.
Jaz
Old 01-13-2008, 05:16 PM   #4
Post
The water temp is between 110-120 F; however, we will keep the ambient temp between 62-72 F.
The hardwood we chose is 3/8 inch solid teak.
Does 5" Hardwood Solid need to be glued down as well as nailed down. reibuild Flooring 2 08-03-2007 10:37 PM
Hardwood over concrete slab El Buey Flooring 9 08-02-2007 07:42 AM
Adding radiant heat to existing slab Seabass HVAC 9 04-27-2007 04:10 PM
Hardwood in kitchen over concrete slab Markvonjinn Flooring 12 05-09-2006 09:37 AM
