-   -   Hardwood glued directly to raidiant-heat slab?? (http://www.diychatroom.com/f5/hardwood-glued-directly-raidiant-heat-slab-15514/)
High Desert Man 01-12-2008 11:02 AM
I have about 1300 ft of hardwood to put down and I have a slab with radiant heat (hydronic tubes embedded in slab). Has anyone done this without first putting down a wood subfloor? I found a glue that is recommended specifically for hardwood to radiant concrete substrate. Any sugggestions will be much appreciated! I'm in NM and humidity shouldn't be an issue.
redline 01-13-2008 01:27 PM
What is the temp that the radiant is set at?
JazMan 01-13-2008 03:55 PM
Hi High,
You say hardwood, so I assume it's 3/4" solid as apposed to engineered hardwood? If that's the case my answer is no. The traditional 3/4" has to be nailed.
Jaz
High Desert Man 01-13-2008 05:16 PM
The water temp is between 110-120 F; however, we will keep the ambient temp between 62-72 F.
The hardwood we chose is 3/8 inch solid teak.
