Hardwood Floors Rough Patches After 2nd Coat - Flooring - DIY Chatroom Home Improvement Forum
Old 07-27-2009, 04:54 PM   #1
Hardwood Floors Rough Patches after 2nd Coat
Hello all! I just put my 2nd coat of oil based varithane on my freshly sanded floors with a lambs wool applicator and after it dried i saw some rough patches. Is that because there's too little varithane in those areas? Should I sand those areas a bit more before i do a 3rd uniform coat on the whole floor or should I just do those spots?
In one area it appears there's some type of scrape in the dried varithane; it's small but how should I fix that?
Any help would be greatly appreciated!
MD_Fisher is offline   Reply With Quote
Old 07-27-2009, 06:01 PM   #2
Wood Flooring & Carpentry
lawndart's Avatar
Sounds like raised grain.. What steps did you take from start to finish while sanding the floor?
Best New York Flooring Installers For Hardwood Floors
lawndart is offline   Reply With Quote
Old 07-28-2009, 02:16 AM   #3
I sanded the edges with an edger usinga square sander (oriiginal coat was worn down to the wood in patches) once with 35 and once with 60, vaccuumed, ragged, used a lambswool applicator to seal it (varithane floors oil based), waited 4 hours, added a second coat. I checked it closer today and found there was a slight recession, and it was dull. I think I missed a few patches. Does that sound right to you?
Easy maintanence and child friendly Hardwood floors? gante Flooring 11 04-12-2016 12:20 PM
Newly refinished hardwood floors are too rough StevenSmith Flooring 11 09-25-2010 09:03 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
polyurethane coat for hardwood floors. christy123 Flooring 2 12-10-2006 11:20 PM
