Old 06-08-2011, 04:22 PM   #1
Hardwood Floors Paint
Ok so I'm making a table and I'm using hardwood flooring as the tabletop to get a basketball court design on it. So I don't know what type of paint to use or how to get the basketball court look. As of now I googled it and they use a high gloss polyurethane to make it shine but i'm concerned that it won't look right and i'm also not sure what type of paint to use... So right now I was going to use an acrylic paint then a semi gloss varnish then a high gloss polyurethane. Would a lacquer be better. I am also using a decal for the center court image when should I put that on? After the varnish but before the high gloss polyurethane or lacquer?
wpsweet is offline   Reply With Quote
Old 06-08-2011, 09:26 PM   #2
woodman58's Avatar
Try the sister site linked below. They will better at helping you.
http://www.woodworkingtalk.com/f8/
woodman58 is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Refinishing hardwood floors (oak) - damage control! jeffpas Flooring 3 02-21-2011 10:00 PM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
Removing carpet pad and paint from hardwood floors Rahci Flooring 10 05-14-2008 02:54 PM
Pattern of hardwood to existing hardwood floors garnet4ever Flooring 4 07-31-2007 04:34 PM
