Old 01-24-2009, 06:51 PM   #1
Hardwood floors installed over 1/2" and 5/8" subfloor
We are looking to install some new 5/16" Brazilian Walnut hardwood in our house. I started ripping up a small portion of the existing 5/16 hardwood to see what was underneath. I discovered the whole floor which includes hardwood and tile was installed over top of a subfloor made from a layer of 1/2" plywood over joists on 16" centers. On top of that 1/2" plywood there is a 5/8" board that looks like mdf or some sort of particle board. The tile and hardwood was attached to that.
I'm planning to just rip up 5/8" board with the floor since they glued the hardwood down and its a bear to get up and smooth. What should I put down in its place? Would another 5/8" board give proper support?
interplexr is offline   Reply With Quote
Old 01-25-2009, 02:00 PM   #2
Tileguy
JazMan's Avatar
Install new 5/8" plywood underlayment. Get a decent grade like B/C exposure 1, which means the glue is exterior grade. Leave an 1/8" between between sheets and at least 1/4" at the perimeter and all vertical objects.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Tags
floor, hardwood, plywood, subfloor, tile
1/2" or 5/8"? Mr. Michael Plumbing 2 04-25-2007 09:06 PM
