Hardwood Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 05-11-2011, 10:05 PM   #1
hardwood floors
Getting ready to install hardwood floors in my living room, it has plywood floors that are unlevel in spots , how important is it to have the floors level??
Clarence is offline   Reply With Quote
Old 05-11-2011, 11:23 PM   #2
I justinstalled 3/4"x5" hardwood in my living room and dining room.
I did sand some of the joints in the subfloor that weren't even and cleaned the blobs of drywall compound off. I supposed you could fill in the low spots with floor leveler if you wanted. 3/4 inch hardwood will span most of the dips in the floor anyway. make sure to run the hardwood perpendicular to the floor joists. how unlevel is your floor?
Old 05-12-2011, 05:14 AM   #3
Too Short? Cut it Again!
Think this is the key question here. Would something like a cork underlay even things out enough? It would also give you a bit of sound and thermal insulation. Or are we talking major sags or high spots in the subfloor?
Old 05-14-2011, 01:33 PM   #4
The wood manufacturer provides in every box installation instructions typically the subfloor must be flat, not level,within 3/16" in 10'. Take a string and check if it has dips more than 3/16" they must be leveled within the 3/16" OR the manufacturer will not be liable for what happens if you do not. Same for bumps higher than 3/16". Always follow mfg's guidelines and you will suceed.
wood inspector is offline   Reply With Quote
Easy maintanence and child friendly Hardwood floors? gante Flooring 11 04-12-2016 12:20 PM
Old Glue on Original Hardwood Floors! gh4444 Flooring 5 02-11-2012 01:13 PM
New buckled hardwood floors Angela3511 Flooring 12 07-16-2009 08:58 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
