Hardwood Flooring Under Sub Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 08:23 PM   #1
Hardwood flooring under sub floor
My kitchen has 2 layers of peal & stick tile. Under that is a sub floor then hardwood floors. Between the sub floor and hardwood flooring there is some kind of hard cardboard like sticky material. how do I get that sticky cardboard like material up without ruining the hardwood underneath?
Dollface is offline   Reply With Quote
Old 10-17-2011, 08:40 PM   #2
Sub floor over hardwood
There is a sub floor over my hardwood floor in the kitchen. In between the two is a thin stiff sticky cardboard like material. How do I remove the sticky cardboard like material without ruining the hardwood underneath?
Old 10-17-2011, 08:49 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,818
Very carefully.
All joking aside......depends on what the material reall is. I would try a hair dryer to warm up a section and see if it lifts up. If it's sticky...then heat will most likely make it easier to remove.
If that does not work....then expect to do a lot of work. Pretty much figure on having to completely redo the floor.
Old 10-17-2011, 08:51 PM   #4
DIY staff
Rewards Points: 7,174
Without seeing a picture I can only give you an educated guess.
The card board looking stuff is Masonite---Paper fibers compressed with glue--
Get under an edge with a flat pry bar and start pealing it up--drive the flat bar under with a hammer as far as you can----then smack the raised area with the hammer.
The Masonite will break --allowing you to work on smaller pieces at a time.
Two flat bars speed things up.
I think you will find staples---good luck with those..----Let us know if you do--Some of the members have good ideas on that issue.---Mike---
Old 10-17-2011, 08:53 PM   #5
DIY staff
I just reread your post----that glued down card board stuff could be whats left from an old vinyl floor covering---See if you can post a picture.
Old 10-17-2011, 09:01 PM   #6
I will be ripping out the sub floor in the morning and will post a pic then. Thanks
Old 10-17-2011, 09:05 PM   #7
DIY staff
Thank---A picture speaks a thousand words--
Old 10-17-2011, 10:12 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 388
That layer is probably the 1/4" underlayment which should have been stapled on to the hardwood to make a good base for the vinyl tiles.....Probably. Could be Masonite, luaun or ?
BTW, it is not a subfloor, it's an underlayment. The subfloor is the thick layer of wood on the joists, the hardwood is nailed to the subfloor.
You need to remove it, but we don't know what you plan to do after. What kind of flooring will you be installing? Pics will help.
Jaz
Hardwood flooring mess options WillK Flooring 3 07-15-2011 09:32 AM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
unique problem with hardwood floor seanbellay Flooring 15 05-02-2010 06:53 PM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 10:20 AM
