Hardwood Flooring Transition
try to put a board accross, so that it runs paralel to the tile, then but all your 45 cuts into that one... then grout between the board accross and the tile... that way you don't have to install a transition that's going to be on top....
this is the closest pic to what i'm trying to say.... you see the section that meets the new room at an angle has a board running accross all the others....
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 50% down, 50% after all your complaints....
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. hardwood floors, To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
