Old 03-28-2011, 12:47 PM   #1
Hardwood flooring sub floor problem
Good day all;
I just ripped up some laminate that was in the master bedroom, and am going to lay hardwood 3/4" x 3 1/4". In the subfloor where the OSB butts up together over the floor joyce they have pressed up together and raised causeing a very uneven part in the floor. How do I fix this or work around it ?
Scott
campbell804 is offline   Reply With Quote
Old 03-28-2011, 02:29 PM   #2
woodman58's Avatar
From what you discribe you can use a belt sander to sand to joints down.
woodman58 is online now   Reply With Quote
Old 03-28-2011, 02:42 PM   #3
Civil Engineer
OSB is prone to expansion if it gets moist, which is I suspect what happened. It is supposed to be installed with a 1/8 inch gap between sheets to reduce the chance of upraising if the subfloor gets damp, or absorbs moisture from the air. I am guessing the subfloor was installed without a gap, and while you can certainly sand the joint down, there is a chance the subfloor will raise up at the same location, causing an uneven floor.
I suggest you cut a 1/8 inch gap into the subfloor between the sheets, if there is no gap. Use a circular saw with a track, and use a carbide nail cutting blade. Set the depth to the thickness of the subfloor, and cut the grooves in. Once cut, you can sand smooth and you will most likely have permanently cured the problem.
Daniel Holzman is online now   Reply With Quote
Old 03-28-2011, 03:47 PM   #4
Thanks alot gentleman for your hasty replies
I have already cut the grooves and it worked great !!! Now I just have to get my hands on a belt sander to sand down what already has been pushed up. Should be laying the hardwood tomorrow now.
Scott
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 07:06 PM
Hardwood flooring cupping Brian Lewis Flooring 14 12-06-2010 03:19 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
What type of Hardwood Flooring for Concrete Slab? talk show host Flooring 5 01-22-2010 09:37 AM
Adding a partition wall to a room with hardwood flooring Badfish740 Remodeling 4 12-29-2008 08:54 AM
