Hardwood Flooring On Stairs / Split Level - Flooring - DIY Chatroom Home Improvement Forum
Old 03-20-2009, 11:55 AM   #1
Question
Hardwood flooring on stairs / split level
Hi folks -
Any advice on how to do hardwood on stairs? Could I install the normal planks for the tread and use nosing or do I need to buy the one-piece solid wood treads from the local flooring shop. I know the second option gets pretty pricey so I'd like to make the planks work if that's doable.
The other dilemma is the flooring I'm putting in will have a visible edge since the upstairs is part of a split level. Should I just use stair nosing around the exposed edges on the flooring. I did a quick drawing attached if that helps....although I mean to say the wall is on the LEFT as you look at the drawing.
Thanks much for any input!
Hardwood flooring on stairs / split level-problem.jpg
Badger_DIYer is offline   Reply With Quote
Old 03-20-2009, 01:35 PM   #2
I believe the way to go is to line the upper level with landing treads on the edges?
Old 03-20-2009, 04:02 PM   #3
Floorwizard's Avatar
First off...great pic. You rock!
You could go either way...planks or full pieces.
If you have railing then be carefull. The floor cannot be pinched by screwing the railing thru the lam and subfloor and the stability will be poor if you only screw thru the lam.
Floorwizard is offline   Reply With Quote
Old 03-20-2009, 04:18 PM   #4
Lam?
Sorry, newbie here. By "Lam" do you mean laminate? I'll be using hardwood, but I assume it doesn't matter?
Old 03-20-2009, 05:00 PM   #5
Correct....same diff-
Tags
stairs , stairway , treads , trim , wood flooring
DYI Project - Hardwood Flooring Install in Hall and Bedrooms godmaster Flooring 9 04-26-2009 09:22 PM
Hardwood flooring/ stairs question 2long4u Flooring 12 01-15-2009 07:56 PM
