Hardwood Flooring Repair - Flooring - DIY Chatroom Home Improvement Forum
Old 05-09-2012, 11:36 PM   #1
I removed a wall in my kitchen, and now have a gap that is 7 inches wide running across the floor. The Hardwood flooring in the Kitchen runs in the same direction as the Hardwood flooring on the other side of the wall I removed. What would be the easiest way to repair the gap. Would I cut the gap the whole length of floor, and run flooring straight across the floor so it is almost like a separation of rooms. Or blend in the floor piece by piece. I do have closets that have the same flooring. Just not sure what would be best?
Here Is a picture of floor:
Hardwood Flooring Repair-hardwoodflooring.jpg   Hardwood Flooring Repair-hardwoodflooring1.jpg
pkyne78 is offline   Reply With Quote
Old 05-10-2012, 05:19 PM   #2
It would be best to stager each row on both sides of the gap to then fill in the rows. This will usually make it to where you can not tell it was patched. The main issue with this is you have to refinish the floor after patching to get it to blend. If you want to tackle this yourself, you will need a multi tool that is able to cut boards out without damaging the boards on either side of it. I prefer the Fein Multimaster. Just google it and you will see what it does. Their are cheaper alternatives, since this may be the only time you ever do this. Some of the alternative brands are Rockwell, Dremel, & Bosch.
RhodesHardwood is offline   Reply With Quote
The Following User Says Thank You to RhodesHardwood For This Useful Post:
pkyne78 (05-11-2012)
Engineered hardwood flooring - depression repair MShomeowner Flooring 7 02-06-2011 04:00 PM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 07:06 PM
Hardwood Flooring Replacement SLstlouis Flooring 1 03-10-2010 07:07 AM
What type of Hardwood Flooring for Concrete Slab? talk show host Flooring 5 01-22-2010 09:37 AM
BOSTITCH Hardwood Flooring Stapler Ciprillius Flooring 3 11-28-2007 08:16 AM
