Hardwood Flooring Question - Flooring - DIY Chatroom Home Improvement Forum
Old 10-19-2007, 01:28 PM   #1
Hardwood flooring question
Can you install pre finished hardwood flooring in the same direction as your beams.
TonyD
TonyD is offline   Reply With Quote
Old 10-19-2007, 01:38 PM   #2
doing that probably requires you to change/add more your subflooring to somthing stronger, such as 3/4 plywood...etc.... whether it is prefinished or not has no baring.
KUIPORNG is offline   Reply With Quote
Old 10-19-2007, 11:39 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 290
You mean joists not beams. You should always install planks across the joists. Your subfloor is probably 3/4" thick already, but that is standard.
Jaz
JazMan is online now   Reply With Quote
Old 10-23-2007, 12:12 AM   #4
thanks for the reply.
TonyD
Old 10-26-2007, 11:15 PM   #5
Floorwizard's Avatar
A floating prefinished hardwood can run either direction.
Floorwizard is offline   Reply With Quote
hardwood flooring Katumba1 Remodeling 4 09-06-2007 01:59 PM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 06:45 PM
