-   -   Hardwood flooring question (http://www.diychatroom.com/f5/hardwood-flooring-question-12526/)
TonyD 10-19-2007 01:28 PM
Can you install pre finished hardwood flooring in the same direction as your beams.
TonyD
KUIPORNG 10-19-2007 01:38 PM
doing that probably requires you to change/add more your subflooring to somthing stronger, such as 3/4 plywood...etc.... whether it is prefinished or not has no baring.
JazMan 10-19-2007 11:39 PM
You mean joists not beams. You should always install planks across the joists. Your subfloor is probably 3/4" thick already, but that is standard.
Jaz
TonyD 10-23-2007 12:12 AM
thanks for the reply.
TonyD
Floorwizard 10-26-2007 11:15 PM
A floating prefinished hardwood can run either direction.
