Hardwood Flooring Pro's Best Practices - Flooring - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 01:20 PM   #1
Willing to listen
Rewards Points: 223
We have 3/4" red oak hardwood through out our 1 story ranch with the exception of two kids bedrooms and the Master bedroom. Would like to add to the master. Not exactly sure but they are the narrow ~2.5" strips. Original material was a pre-finish supplied by the builder.
Would a professional consider it acceptable to install the new floor at 90 degrees to the existing?....or is that considered "odd" looking. Seems like it would be difficult at best to try to go back and mix it into the old to keep it all running in the same direction.
Help settle the debate for me and the misses...needs some Pro's recommendations, thank you.
Done That is offline   Reply With Quote
Old 08-22-2011, 01:25 PM   #2
Experienced
Jackofall1's Avatar
Not a pro, but have laid a fair amount of HW, I would keep it in the same direction, I believe it looks better and if you look at the floor joist my guess is the HW is laid perpendiculat to them, as it should be.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
Done That (08-22-2011)
Old 08-22-2011, 01:54 PM   #3
Willing to listen
Rewards Points: 223
Didn't even consider the joists, yes you are correct the current HW is perpendicular.
How "big" a job is it to mix new into old across an existing 32" doorway into the bedroom?
Old 08-22-2011, 02:16 PM   #4
Experienced
Jackofall1's Avatar
For a pro, they do it all the time, I am sure they could do it right in stride with and not miss a beat.
Mark
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 06:06 PM
Hardwood flooring cupping Brian Lewis Flooring 14 12-06-2010 02:19 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 08:53 PM
DYI Project - Hardwood Flooring Install in Hall and Bedrooms godmaster Flooring 9 04-26-2009 09:22 PM
