Old 03-11-2013, 12:12 PM   #16
greetings from Bolivia
harrymontana's Avatar
Send a message via Skype™ to harrymontana
Hardwood Flooring Pricing and Install
Originally Posted by Seattle2k View Post
Also, it's usually advised to put down a urethane moisture barrier, before gluing down hardwood to concrete, so factor in that cost.
or plywood underflooring, this is against moisture variations that will negativelt effect you top wood floor and levells at the same time your entire floor. With the help of plywood underflooring, installation of the wood floor can then be done with a nailing machine (low installation cost per sqft)
harrymontana is offline   Reply With Quote
Old 03-12-2013, 10:15 AM   #17
So you are saying not to glue down to the cement?
7 VII 7 is offline   Reply With Quote
Old 03-12-2013, 10:35 AM   #18
747
registered
747's Avatar
Go buy the wood floors you want. Contact these guys to lay.
All Wood Flooring 13314 Lydia St. Silver Spring, MD 20906
Good luck.
Ps. They did the hardwood floors for the This old house project in DC (rowhouse). The floor they went with.
2 1/4" Oak Prefinished Hardwood Floors
PRGS2S[BR] Style: Casa de Colour Select Gunstock
Manufacturer:
Lumber Liquidators
747 is offline   Reply With Quote
Old 03-12-2013, 09:22 PM   #19
no, the plywood is screwed on the concrete floor and on top of the plywood the hardwood slats are glued and nailed for a perfect installation result. The funtion of the plywood is for insulation, prevents moisture transfering from the concrete onto your hardwood slats and provides a levelled underfloor.
Old 03-13-2013, 01:50 PM   #20
I pulled up some of the hardwood on my floor and there was no plywood. Just black glue down to the concrete.
Old 03-15-2013, 05:08 PM   #21
Professional
UniqueWoodFloor's Avatar
Assuming these are experienced installers with a good reputation these prices are not extremely high. For maple floors in Minnesota you're looking at roughly $5.00/sqft, wood adhesive for glue down $1.00/sqft, Demo $1.00/sqft, and Installation $3.50/sqft. This brings us to roughly 10.50/sqft. Now please keep in mind when installing prefinished flooring the milling makes a huge difference. Do not go cheap on the installation or material. The best installers could do a bad job with a bad product and vice-versa.
UniqueWoodFloor is offline   Reply With Quote
Old 03-18-2013, 10:16 AM   #22
We are torn between Shaw flooring and Mirage flooring. Mirage will be $600 more than the Shaw, but is it really worth the extra $600?
Old 03-18-2013, 11:39 AM   #23
Professional
From what I've heard Shaw is a decent brand with superior milling compared to brands around the same price point. However, Mirage positioned much higher in the market and so is their pricing. If you are willing to do some research it is best if find the material you want and then have your contractor install it. If you go to a display dealer the sales rep should have more to say about each brand as they should have received training directly from the manufacturer's rep.
Tags
hardwood flooring
Pricing laminate stair install nicky Flooring 6 09-02-2012 05:09 PM
Thinking about DIY Hardwood vs Laminate HolyGrail Flooring 1 02-12-2012 10:31 AM
3/8" Eng Hardwood Install??? Go Chargers Carpentry 1 10-28-2010 05:39 PM
Trafficmaster Allure Commercial Confetti Dark Grey Vinyl Flooring (24 Sq. Ft. Per Cas bennyjets Flooring 3 08-09-2009 11:50 PM
Help On Pricing Work Renovator General Discussion 1 05-30-2006 01:33 PM
