Hardwood Flooring Over Slab?? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 11:01 AM   #1
Rewards Points: 39
hardwood flooring over slab??
Hi all,
We're in the process of trying to pick out flooring to cover a slab in our EIK/dining area. We were hoping to be able to go with a pre finished hardwood, but I'm concerned about attaching the flooring.
Height is a concern because of two in-swing doors in the room, which leave us with a little over 1 1/4 " over the slab. Is there an adhesive method that would allow me to put the hardwood down over 1/2" plywood or anything????
Any suggestions would be appreciated, Thx.
Sam
Sampson is offline   Reply With Quote
Old 03-26-2011, 05:57 PM   #2
woodman58's Avatar
You can buy hardwood flooring that has the same wear thickness as a solid. Then you can glue it to the sub floor. You will have to make sure the floor is flat with no high or low spots.
woodman58 is offline   Reply With Quote
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 06:06 PM
Hardwood flooring cupping Brian Lewis Flooring 14 12-06-2010 02:19 PM
What type of Hardwood Flooring for Concrete Slab? talk show host Flooring 5 01-22-2010 08:37 AM
Flooring over slab mike6x7 Flooring 1 01-07-2010 07:42 AM
