Hardwood Flooring Over Crawlspace - Flooring - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 09:16 PM   #1
Rewards Points: 27
Hardwood flooring over crawlspace
Is it a bad idea to install real hardwood over a crawlspace. We found some nice gunstock maple that we like for a good price. I live in St. Louis area. It is a vented crawlspace. I plan to put 6 mil plastic over the dirt ground.
jjones1020 is offline   Reply With Quote
Old 04-09-2013, 09:59 PM   #2
Dave Sal's Avatar
Rewards Points: 728
I have solid hardwood that I installed over my crawlspace back in the 80's. There have been absolutely no issues at all. My crawl space was vented with a concrete floor. I have since closed off the vents and insulated the rim joists and it stays nice and warm now. If you seal up your dirt floor properly with 6 mil plastic you should be fine.
Dave Sal is offline   Reply With Quote
Old 04-10-2013, 12:47 AM   #3
Rewards Points: 744
As long as you have no standing water down there and a full poly vapor barrier on the ground, you should be fine. All hardwood flooring manufacturers should have this information and any other site requirements in their instructions.
Seattle2k is offline   Reply With Quote
Mixing different types of hardwood flooring dwatts Flooring 4 06-28-2012 04:24 PM
Laminate/Synthetic flooring over hardwood nancyu Flooring 5 06-18-2012 12:48 PM
strand bamboo flooring over previously sanded/refinished hardwood flooring Prather Flooring 1 05-28-2012 05:05 AM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 06:06 PM
Adding a partition wall to a room with hardwood flooring Badfish740 Remodeling 4 12-29-2008 07:54 AM
