Old 01-31-2013, 09:21 PM   #1
Hardwood Flooring - clean? refinish?
Currently in the middle of a bathroom remodel. The door floor threshold is a transition from hardwood to tile. The second piece of hardwood is original (see photos). It is stained or scratched, not sure. I tried a hard cleaning with soap and a toothbrush - helped a little but no luck. Any ideas how to clean better? Does it need to be sanded and refinished? I really don't want to remove/replace the hardwood pieces and all adjacent trim.
Hardwood Flooring - clean? refinish?-dsc06066-resize.jpg   Hardwood Flooring - clean? refinish?-dsc06068-resize.jpg
Windgate9 is offline   Reply With Quote
Old 02-01-2013, 10:37 AM   #2
If you use a marble threshold most of that would be covered up.
Old 02-01-2013, 01:06 PM   #3
Tileguy
JazMan's Avatar
How do you plan to finish the tile? A marble threshold would be the best way, but you'd want to remove the one piece of wood and replace it with ply, then add your concrete backer or membrane.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Hardwood flooring installation horsthelmut Flooring 9 05-12-2012 01:21 AM
Hardwood Flooring Repair pkyne78 Flooring 1 05-10-2012 05:19 PM
Hardwood flooring cupping Brian Lewis Flooring 14 12-06-2010 03:19 PM
Diagonal plank subfloor preparation for Hardwood Flooring? Fingers Flooring 3 11-26-2009 12:03 PM
Hardwood Flooring transition msfmatt Flooring 2 05-21-2009 08:57 AM
