-   -   Hardwood Flooring - clean? refinish? (http://www.diychatroom.com/f5/hardwood-flooring-clean-refinish-170700/)
Windgate9 01-31-2013 08:21 PM
2 Attachment(s)
Currently in the middle of a bathroom remodel. The door floor threshold is a transition from hardwood to tile. The second piece of hardwood is original (see photos). It is stained or scratched, not sure. I tried a hard cleaning with soap and a toothbrush - helped a little but no luck. Any ideas how to clean better? Does it need to be sanded and refinished? I really don't want to remove/replace the hardwood pieces and all adjacent trim.
joecaption 02-01-2013 09:37 AM
If you use a marble threshold most of that would be covered up.
JazMan 02-01-2013 12:06 PM
How do you plan to finish the tile? A marble threshold would be the best way, but you'd want to remove the one piece of wood and replace it with ply, then add your concrete backer or membrane.
Jaz
