Hardwood Flooring Basics - Flooring - DIY Chatroom Home Improvement Forum
Old 11-19-2011, 09:50 AM   #1
Rewards Points: 338
Hardwood flooring basics
Someone started our kitchen floor but stopped about ten inches from the cabinets. I have a box of hardwood flooring they left behind. I see paper under the flooring...how do I finish the floor? Lay down the brown paper, attach the boards (they are tongue and groove). Do I put glue in the tongue and grooves or under the hardwood on top of the paper?
Thanks anyone!
dougp23 is offline   Reply With Quote
Old 11-19-2011, 06:03 PM   #2
Civil Engineer
Rewards Points: 4,522
If this is 3/4 inch thick hardwood, tongue and groove, you typically install over rosin paper or felt, and drive nails diagonally through the tongue into the subfloor. No glue. The last strip cannot be blind nailed as the cabinet gets in the way, and is typically face nailed using finish nails, the nails are driven in below the surface, and putty is used to cover the nails. Make sure you leave an adequate gap at the edge, typically 1/2 inch, covered with molding.
Daniel Holzman is online now   Reply With Quote
First Timer - Questions About Hardwood Flooring for Stairs sunshine54 Flooring 0 10-16-2011 11:44 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 06:15 AM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 07:06 PM
Hardwood flooring cupping Brian Lewis Flooring 14 12-06-2010 03:19 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
