Old 02-12-2007, 01:27 PM   #1
Default Hardwood Flooring in Basement
I know that many people feel strongly that hardwood flooring should not be installed over concrete, whether it be in a basement or on a slab. I would like to install it in my basement, and thought that I could possibly bypass most of the moisture/uneven floor risks by essentially building a wall, sheeting it with 3/4 plywood, laying the wall on the floor, and installing the hardwood on it. I would probably use some plastic and insulation under it as well. Has anyone heard of thing being done before? Any potential problems that I may not be thinking of?
Thanks.
Brad
bcrwfan is offline   Reply With Quote
Old 02-12-2007, 02:33 PM   #2
Default you are talking about drycore alike subflooring....
I almost goes with the same route... except there isn't really one article suggesting this in the web... and I chicken out.... I will think it would be ok personally if the basement has no leak problem.... people not doing it just afraid one day there is leak and the whole thing is damage and unfixable where as other types of material can somewhat let dry and still resuse.... but I think this is not really a good reason for not using it... other people also said basement is damp and not suitable... but I feel my basement is so dry and this is not a good reason applicable to me either.....so I support you and go ahead.... but you probably will receive over 90% opposite opinion....
KUIPORNG is offline   Reply With Quote
More On This Topic
According to the American Academy of Allergy, Asthma and Immunology, there are approximately 40 million people who suffer from indoor allergies. You can reduce allergy symptoms by avoiding allergens that trigger your allergies. It takes only a little... Read More »
Hard Wood Floor Care
Hard Wood Floor Care by Expert Village
Caring for hard wood floors is something people debate on a lot. First of all, you want to sweep a lot. You want to use a broom that has bristles that are frayed at the end so that way you don’t have to mess with scratching the ground, scratching... Read More »
Hi, I'm Jeremy Blackwell I'm here today to help you get started on your basement remodel project. This is a GFCI outlet that's required in bathrooms. The reason this is required is because if any water were to just drip on the outlet or if a hair dryer... Read More »
How to Dry a Damp Book
How to Dry a Damp Book by Expert Village
Once you have gotten your book dry enough so that it is no longer saturated or even partially wet you have a damp book. This is characterized by mainly the covers being wet, you might have a couple of pages inside that are a little bit damp but for the... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Remodeling a basement can be a big task. When you want to remodel your basement, you first want to think about how big it is and what you want to do, with... Read More »
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 03:04 PM
Basement flooring choices Brik Building & Construction 23 01-27-2007 04:38 PM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 11:08 AM
hardwood in basement TorontoJohn Flooring 7 01-05-2006 11:56 PM
Hardwood Flooring is one of the Most Important Design Elements in your Home Decor doctorhouse Flooring 1 12-22-2005 10:17 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
