Old 07-06-2007, 11:19 PM   #1
Hardwood Flooring
Should I put any kind of barrier in between the plywood and the hardwood I am getting ready to install?
timmbukk is offline   Reply With Quote
Old 07-07-2007, 04:39 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Hardwood Flooring
I would obviously assume that you are referring to the plywood that constitutes the "sub-floor". The answer is yes. Either use Rosen Paper or 15 lb roofing felt in order to avoid squeaks (wood surface against wood surface).
Have you done all your research on installing hardwood floors? Just in case you haven't please review the information on the links below. Especially points regarding acclaimation of the wood flooring prior to install and also, the direction of the floor joists. That direction affects how you will install the flooring planks.
links:
http://www.hammerzone.com/archives/f...k1/stapled.htm
http://www.hometips.com/articles/woodfloor.html
- Build Well -
Old 07-11-2007, 11:14 PM   #3
Floorwizard's Avatar
Hardwood Flooring
what kind of hardwood and how will it be installed?
atlantic - what if it was engineered, or thin solid glue down?
That would be funny to use the rosin
But if it is 3/4 nail down....then rosin away...
Floorwizard is offline   Reply With Quote
Old 07-12-2007, 09:12 AM   #4
Hardwood Flooring
use 15# tar paper
rolldodge is offline   Reply With Quote
Old 07-12-2007, 12:38 PM   #5
Hardwood Flooring
Do you guys overlap the red rosin paper or tar paper? I've heard from some people that on a prefinished floor install they could see the "ripples" of where the paper overlapped. I'm installing hardwood on 1st floor with a full basement underneath, is it okay to just butt the ends of the tar paper to each other?
AllGoNoShow is offline   Reply With Quote
Hardwood Flooring in Basement bcrwfan Flooring 1 02-12-2007 01:33 PM
Flooring hardwood v engineered or laminate skits Flooring 1 07-12-2006 10:03 AM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 06:45 PM
