Hardwood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-03-2011, 06:03 PM   #1
Rewards Points: 212
Question
Hardwood flooring
hi i laid some 3/4 oak prefinished and it all came out good except for some of the butt joints not coming out flush with eachother. i nailed the floor with a pneumatic cleet nailer. the side joints all came out nice and smooth but some of th end joints did not. the floor was climatized also. has this ever happened to you? what is the reason for this? or os this typical for prefinished?
bluebird5 is offline   Reply With Quote
Old 02-03-2011, 06:09 PM   #2
Buying the first round
LIHR's Avatar
Pre-finished has nothing to do with this, but quality control does.
Considering all went well except the end joints I would suspect inconsistencies in the end t&G milling.
Who is the manufacture?
http://www.ranteso.com/
LIHR is offline   Reply With Quote
Old 02-03-2011, 07:59 PM   #3
Rewards Points: 200
It's called overwood . Manufactured related . If there is more then 5% of the wood affected i would have someone out to the house .
Floor Doc is offline   Reply With Quote
Old 02-03-2011, 08:00 PM   #4
Rewards Points: 212
well it said corbin or somehing like that on the box. it was like 2 dollars a square foot
Old 02-03-2011, 08:01 PM   #5
Rewards Points: 212
just curious what is the best hardwood out there that will come out the smoothest?
Old 02-03-2011, 08:05 PM   #6
Rewards Points: 200
Do you mean what are some of the better Mills ?
Old 02-03-2011, 08:41 PM   #7
Rewards Points: 212
well i guess i was talking mor about brands but if a mill is a brand than yes. I have heard of bellawood and bruce are those any good?
Old 02-04-2011, 02:27 AM   #8
Rewards Points: 200
bellawood is crap . Bruce makes a cabin grade product that is not to bad . you will still get a lot of bowed boards , boards with pinched end joints . [etc]. should be around $4.00 a foot .
Kahrs , Mirage are two of the better mills that make a good product .
Old 02-06-2011, 09:58 PM   #9
in my 16+ plus years of installing flooring, this problem is all too common with prefinished hard flooring from ALL manufacturers. Wood is imperfect no matter how good it is milled. it has a 5 % grading deficiency. purchasing a product with beveled ends may have solved the problem. i explain this problem to homeowner before i install. u can shim under boards that sit too low during the installation, (extremely time consuming) or u can accept these flaws as imperfections in a natural product.
acglobal is offline   Reply With Quote
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 06:06 PM
Hardwood flooring cupping Brian Lewis Flooring 14 12-06-2010 02:19 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 08:53 PM
What type of Hardwood Flooring for Concrete Slab? talk show host Flooring 5 01-22-2010 08:37 AM
DYI Project - Hardwood Flooring Install in Hall and Bedrooms godmaster Flooring 9 04-26-2009 09:22 PM
