Old 11-20-2006, 06:27 PM   #1
Hardwood Flooring
Can hardwood flooring be installed on a wall?
jerome8283 is offline   Reply With Quote
Old 11-20-2006, 09:49 PM   #2
renovations
Hardwood Flooring
Certainly you can do it, it's just hard to walk on like that.
My house was originally an old logging dormitory from the 30's, it is built with no studs, just shiplap (vertical), siding (horizontal) with cedar shingles on the outside. On the inside (all six surfaces) is 1x4 t&g clear fir. Someone came along years later and added 2x2 on the inside and wood veneer panelling with a layer of paper-backed tin foil for insulation. So... certainly you can do it, but you might not like the cost today.
Bonus is offline   Reply With Quote
Old 11-20-2006, 11:41 PM   #3
Floorwizard's Avatar
Hardwood Flooring
probably a good engineered wood adhered to the wall will be fine.
Floorwizard is offline   Reply With Quote
Old 11-21-2006, 07:41 AM   #4
Hardwood Flooring
I asked because I saw something in a restaurant that appeared to be flooring on the wall but maybe it was a decorative wainscot? It was a dark cherry wood. I liked the look but have been unable to find it.
Old 12-08-2006, 09:51 PM   #5
Send a message via ICQ to John712 Send a message via AIM to John712 Send a message via MSN to John712
Hardwood Flooring
You need to use some special thing to hold it.
John712 is offline   Reply With Quote
Hardwood Flooring in Basement bcrwfan Flooring 1 02-12-2007 01:33 PM
Flooring hardwood v engineered or laminate skits Flooring 1 07-12-2006 10:03 AM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 06:45 PM
