Hardwood Flooring - 3 Walls And A Sunken Living Room - Flooring - DIY Chatroom Home Improvement Forum
Old 12-08-2007, 04:00 PM   #1
Hardwood flooring - 3 walls and a sunken living room
I am putting hardwood flooring in a Dining room, sunken living room. The dining room has 3 walls and joins the living room. the joists run the length of the rooms north to south. there is 1 step to the living room.
If I start at the north wall in dining room and when I get to the step I will have to make a cut cutting the groove off how do I join the nosing?
Or should I run the flooring north and south which is wrong ?
Or is there a nosing that comes with a groove side?
Any help will be greatly appreciated
Thanks Brent
basledder is offline   Reply With Quote
Old 12-09-2007, 05:34 PM   #2
Mod / ArchiBuilder
Cole's Avatar
Brent, I am having a hard time seeing everything.
Can you sketch a diagram for me?
Cole is offline   Reply With Quote
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 12:03 PM
Reversing direction of wood floor bhyatt Flooring 12 02-04-2008 08:05 PM
Decorating my living room - a mess! mikailani Interior Decorating 4 10-21-2007 04:57 PM
Living room colors-Yellow, White, Sage or Taupe Minak Painting 22 02-21-2007 02:31 AM
Adding a room, footings for all walls, or just new exterior? mt232 Building & Construction 2 09-25-2006 06:55 PM
