Hardwood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 08:16 AM   #1
Hardwood flooring
I have hardwood flooring in my kitchen and half my living room. The floors are under my cabinets and I'm wanting to put down a laminate floor but it isn't as thick as the hardwood. Will I be able to put the floors down I want with out having to take the cabinets out to get all the floors up.
12hood12 is offline   Reply With Quote
Old 03-26-2013, 12:18 PM   #2
why do you want to replace hardwood with laminate? the hardwood adds value to your home, laminate doesn't. if you are removing the hardwood to install the laminate you can just cut the hardwood along the cabinets. you can rent a toe kick saw to cut it but be very careful when using it. since the laminate isn't as thick as the hardwood you will have to install shoe molding along the bottom of the cabinets to cover the gap.
The Following 2 Users Say Thank You to DannyT For This Useful Post:
Dave Sal (03-26-2013), joecaption (03-26-2013)
Old 03-26-2013, 03:39 PM   #3
Rewards Points: 13,712
Unless you build that floor back up if you remove the hardwood it's going to effect all the baseboards, toe kick, door openings.
Why are you not just refinishing the floor?
Nothing will lower the resale value of a home faster then a laminite floor.
Maximum hardwood flooring length EE_Steve Flooring 3 10-20-2012 10:51 PM
Mixing different types of hardwood flooring dwatts Flooring 4 06-28-2012 04:24 PM
Laminate/Synthetic flooring over hardwood nancyu Flooring 5 06-18-2012 12:48 PM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 06:06 PM
Adding a partition wall to a room with hardwood flooring Badfish740 Remodeling 4 12-29-2008 07:54 AM
